I have extracted the .wav audio from a NTSC .avi file. When I try to convert the frame rate described in "https://forum.videohelp.com/viewtopic.php?t=228505" it takes 1 second and produces a zero size file. The Besweet.log file indicates no error. The file is 655Mb and I have tried with smaller files which work, so what is wrong with this one. It is playable and seems OK.
Are you using one of the frontends? Try setting it up again. This version works well for me:
BeSweetGUI v0.7b4. Unzip to its own folder. Then unzip all BeSweet.exe files to the same folder. Try again. It sounds like you're using a GUI and it's not finding the executable. And if I'm wrong in my assumption, try it anyway. BeSweet can be cranky.Pull! Bang! Darn!
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
convert .mkv with non-standard frame rate
By Conrad007 in forum Video ConversionReplies: 2Last Post: 20th Jan 2011, 11:50 -
Trying to convert World Cup game to DVD, have a ? about frame rate
By Roge in forum Authoring (DVD)Replies: 8Last Post: 10th Sep 2010, 06:06 -
Is there a program that can safely convert variable frame rate videos?
By darkzero297 in forum Video ConversionReplies: 1Last Post: 17th Jul 2007, 20:01
